How can I raise my idle 25-50rpm?
Backpacker
One of the belts on my 89, not sure if a drive belt or the timing belt, makes a slightly annoying noise at idle. My bet is on the the timing belt, I just changed it but rechecked the tension after 500 miles and it's pretty close to spec. It's sounds like a rubbing noise, someone described it once as a hive of bees lol but that's an exaggeration.
Anyways, it goes away the second I give it any kind of throttle, even just a little bit where you can barely notice the tach increase. I don't think it's really an issue so I'd like to get rid of the noise by increasing my idle a slight bit. I couldn't find anything in the FSM on how to do this, is it in there and I just can't find it?
Any help would be appreciated!
Edited by Backpacker
