AIIZEE Posted March 14, 2005 Share Posted March 14, 2005 Hey fellas, its been a while. Recently my 92 Pathy will not start, seems to be a very dead battery. It will start with a 20 dollar booster box (pep boys speacial). The battery will not charge and its only about 8 months old. I disconnected the battery while the Pathy was on and all seems fine, running well so its not the alternator. I tightend everything back up shut it doen and it will not start. The lights go on the dash but when i crank it it will just flicker and all goes dead again. I use the booster box and it starts right up. Link to comment Share on other sites More sharing options...
94extreme Posted March 14, 2005 Share Posted March 14, 2005 sounds like the battery.... i don't think your tk should be running after disconnecting of the battery though... Link to comment Share on other sites More sharing options...
hardwaretoad Posted March 14, 2005 Share Posted March 14, 2005 (edited) Sure sounds like a dead coppertop. Is it a Pimp Boy's battery? Probably lucky it lasted 8 months... :oops: Have you done a volt & ammeter check? Is it a sealed battery where you can't check the specific gravity of the cells? At 8 months old, at the very least it should be under warrantee & a replacement given to you prorated. Take it back & have them test it... while you're there see if they'll check your alternator and the rest of your charging system, too. -thnkboutit- It'll run with it disconnected.... Edited March 14, 2005 by hardwaretoad Link to comment Share on other sites More sharing options...
Airrun2002 Posted March 14, 2005 Share Posted March 14, 2005 darn, my original battery in my 95 just crapped out on me last month, I was proud but it sucked that it had to crap out when i needed to go to work. I was verry suprised but it was probly my subs and stereo that did it in. Link to comment Share on other sites More sharing options...
k9sar Posted March 14, 2005 Share Posted March 14, 2005 make sure you have a good connection between your battery posts and the cables. If bad, your battery may be perfectly fine but insufficient power getting to the rest of the vehicle. Jumpstarting would work fine since you clamp onto the cable, not the posts. Throw a volt-meter on the posts, then on the clamps and make sure they read the same. Link to comment Share on other sites More sharing options...
