95 Pathfinder 2WD. Timing marks from Hades?
briano1234
I have a leaking cam shaft seal.
I have all the fru-fru off. but I can't for the life of me get the timing marks to align.
They seem to be the most asinine after thought that I can think of.
There is a finger nail scratch on the oil pump cover that I guess is the crank mark. (why wouldn't engineers make a more noticible marking.............(ARGHHH) I even read where you had to align the dizzy to number one, and then stamp your own Crank mark???????
There are 2 raised dimples on the rear timing belt cover.
The Distributor has a raised Pimple, but that is about 1/4 of an inch from where the Plug wire is.
I have rotated the engine at least 50 times, and I can never get all the marks to agree.
I have removed the plugs and have the number one piston fully up, but the marks are off, if I align it for the left the right is off by at least a tooth. Conversely opposite if I align it to the right cam.
I never worried about the belt marks as it has been replaced by a gates, and I don't know if the original owners had it replaced by Nissan, or a shop.
I just need a little guidance on getting all the marks to agree, I would assume that some belt stretch has occurred, but I wouldn't think that it would of stretched so much that I couldn't split the difference.
I have the Digital version of the oem manual, and the haynes, both show the marks, but for the life of me I can't get them all to agree.... I do know that when I get the thing right,,, I am peening good marks....
Just need some guidance, and am venting a wee bit.
This PF has been through 2 daughters, and a son.... a couple of fender benders that I had to cut and weld body panels for and door replacement....
(Long time VW Diesel/Cabriolet owner/mech.) I thought VW had their engineering issues..not the current cheating kind. At least the marks were there for eternity.
Thanks
Briano.
There should be 40 teeth between the two camshaft marks, and 43 teeth between the drivers side camshaft mark, and the crank mark. All of these being on the pulleys. I would strongly suggest not reusing a belt. A new one will be safer, and the marks will be there to help you.
And for what it's worth, I found this way easier than any VW I have worked on, which is my friend's mk2 jetta (8v) and my 2004 golf.
Thanks so much.
The timing belt is going to be gone......have a new one, as when I got the covers off the timing belt had seen better days, and I know it had to have about 80k on it at the least...... I can't remember when I had to replace the water pump, and the belt looked new then.... I marked the belt and pulleys. and slid it off and back on.
The issue I have is my son can pour a quart of oil in the car, and within 4 days it is on the driveway...... It was leaking from the front right cam.
Now if I can get the front crank seal, some are showing the seal as a different critter.... The one my son brought home has a extended front, so I am assuming that it was incorrect as mine is a flat seal.
I will count the teeth between the marks.
I love the dub gassers, break a belt now worries..... the Diesels were a different matter and I lost a head and 2 pistons when a new to me belt destroyed 2 teeth.... within 10,000 miles..... no worries, got a new engine and 5spd for it rather cheap....... both engines had the same mileage, and lasted me for 20years and 330K before I sold it.
When I get done with this I have 2 water pumps for my cabbies and a new 3 layer top to put on....
