mdwarren289 Posted February 28, 2016 Share Posted February 28, 2016 I had to replace a bad battery after jump starting running it and moving it to my garage. Replaced battery now the engine cranks but does not start. I checked all of the ignition trouble shooting and all seems to be good, just no spark. It has a factory installed security system. Is there any way check if the security system is interrupting the ignition system? Or am I missing something obvious. Vehicle ran fine and started on first crank every time before the battery went south. Link to comment Share on other sites More sharing options...
XPLORx4 Posted March 1, 2016 Share Posted March 1, 2016 I have a 97 LE also. That model year does not have an engine immobilizer security system that relies on transponder chips in the key. I'm able to start the engine with a blank metal key. I have also recently removed the battery for some electrical wiring work and had no problems with the security system afterwards, which is just a theft-alarm.Check out page 216 of this document: https://dl.dropboxusercontent.com/u/9252407/1997_R50_FSM/EL.pdf It is possible that the ignition coil in the distributor failed coincidentally at the same time as the battery. Rockauto.com has new distributors for a little over $100. Link to comment Share on other sites More sharing options...
mdwarren289 Posted March 1, 2016 Author Share Posted March 1, 2016 Old-timer, Thanks for the info. You verified what I thought was going to be the issue. Thanks for the great document also. I could have ruled out the security system a lot sooner if I had this. I guess I can stop looking for the security reset now also. Looks like I need a new distributor in addition to the battery. At least the entire coil system is in the distributor. Just a mad coincidence Thanks again. Link to comment Share on other sites More sharing options...
