ahardb0dy Posted February 2, 2016 Share Posted February 2, 2016 Anyone ever replace the side rear window glass? I know there are 4 bolts but not sure if it is glued in as well. Service manual shows sealant but doesn't say anything about using primer first like it does for the windshield which I know is glued in using urethane. I searched did not find anything, Thanks Link to comment Share on other sites More sharing options...
RIPB.88 Posted February 4, 2016 Share Posted February 4, 2016 Could be butyl. Old school method. Unbolt and carefully slice the glue/butyl away. Shouldnt be too hard. Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted February 9, 2016 Share Posted February 9, 2016 ^^ is correct. 4 bolts and rubber butyl. I heated it up enough to slide a guitar cord through and sawed away. Link to comment Share on other sites More sharing options...
RIPB.88 Posted February 11, 2016 Share Posted February 11, 2016 Harbor freight also sells a cold knife just like the one I have at work, but the piano wire method works pretty well too. Link to comment Share on other sites More sharing options...
