What size bolts for rear trailing arms?(upper and lower)
NovaPath
If I was home, I could get you the exact measurements. I'm certain they're 14mm x 1.5mm, though. You should be able to put a ruler on yours while still installed to get the final length.
Per my post below, you can see that one set of bolts gets cut/sheared off, but the length to the thread end is the same.
http://www.nissanpathfinders.net/forum/topic/39956-my-first-r50/?p=751089
Paid $1.62 for the cheaper bolts from Courtesy Parts (I use "nis10" to save on shipping). Rob Lacy here can surely get them as cheap. The "more expensive" (short) bolts were $2.54. Far cry from your rip-off dealer. Also, keep in mind the OE nuts are PTLN's flange nuts. I'd stick with those.
