r50 to WD21 Parts Interchangeability
stovanovich
Is this what it looks like, noting the bolted shaft tube?
I wonder if that shaft tube would bolt to the other side? On the R200 version it is pressed in and welded...
lol
I'm running a wd21 fan and clutch on it right now...
Most of it will be so custom that what fits on it may not fit other S30's
Edited by MY1PATH
Also, I didn't think the R180 came with the H233B...I thought it was R180/C200 and R200/H233B combos. This was true for most Nissan truck/SUVs here. Does your rear diff have a removable 8-bolt cover?
Yep over here the Diesel Terrano has R180/H233B combo. I've swapped the diff head out before for another H233B one so can definitely confirm that. Stopped putting the C200 in the rear in '90 for Terranos
Good to know! Almost wonder if that setup did exist here then. I actually hadn't seen a coil-sprung C200 until very recently, and that was interesting to see (I was doubting their existence).
Here's the unicorn, in case any one else was curious (note the removable diff cover...):
