MY1PATH Posted August 22, 2015 Share Posted August 22, 2015 Is this what it looks like, noting the bolted shaft tube? I wonder if that shaft tube would bolt to the other side? On the R200 version it is pressed in and welded... Link to comment Share on other sites More sharing options...
MY1PATH Posted August 22, 2015 Share Posted August 22, 2015 Going into? Going into an AWD conversion for an S30 Link to comment Share on other sites More sharing options...
hawairish Posted August 22, 2015 Share Posted August 22, 2015 I wonder if that shaft tube would bolt to the other side? On the R200 version it is pressed in and welded... That's a negative, Ghost Rider. http://www.forum4x4.org/threads/62702-remplacement-du-differentiel-du-pont-R180A-par-un-Quaife Link to comment Share on other sites More sharing options...
hawairish Posted August 22, 2015 Share Posted August 22, 2015 Going into an AWD conversion for an S30 Wicked. New thread: WD21 to S30 Parts Interchangeability Link to comment Share on other sites More sharing options...
MY1PATH Posted August 22, 2015 Share Posted August 22, 2015 (edited) lol I'm running a wd21 fan and clutch on it right now... Most of it will be so custom that what fits on it may not fit other S30's Edited August 22, 2015 by MY1PATH Link to comment Share on other sites More sharing options...
stovanovich Posted August 24, 2015 Author Share Posted August 24, 2015 Also, I didn't think the R180 came with the H233B...I thought it was R180/C200 and R200/H233B combos. This was true for most Nissan truck/SUVs here. Does your rear diff have a removable 8-bolt cover? Yep over here the Diesel Terrano has R180/H233B combo. I've swapped the diff head out before for another H233B one so can definitely confirm that. Stopped putting the C200 in the rear in '90 for Terranos Link to comment Share on other sites More sharing options...
hawairish Posted August 25, 2015 Share Posted August 25, 2015 Yep over here the Diesel Terrano has R180/H233B combo. I've swapped the diff head out before for another H233B one so can definitely confirm that. Stopped putting the C200 in the rear in '90 for Terranos Good to know! Almost wonder if that setup did exist here then. I actually hadn't seen a coil-sprung C200 until very recently, and that was interesting to see (I was doubting their existence). Here's the unicorn, in case any one else was curious (note the removable diff cover...): Link to comment Share on other sites More sharing options...
stovanovich Posted August 25, 2015 Author Share Posted August 25, 2015 Even if it didn't I believe they're old enough now that you can get our gorgeous 2.7L Diesels imported over? Pretty sure I heard that somewhere. Link to comment Share on other sites More sharing options...
