blackpath94 Posted February 26, 2005 Share Posted February 26, 2005 so i have a 94 SE v6 with the stock auto tranny. i have been noticing that it sometimes doesnt shift back down into first gear. like when it starts out its in second gear. when i accelarate away from a stop it starts to move at a much higher rpm and at a much slower speed then it would in first gear. it first happend after a little off-road session but now it seems to happen more often and a little more randomly. if i turn the car off let it sit for a few seconds and turn it back on, the tranny acts normal again. does any one know what is happening? do i need to get the tranny rebuilt or purchase a new one? thanks tom Link to comment Share on other sites More sharing options...
94extreme Posted February 26, 2005 Share Posted February 26, 2005 check under the truck. maybe you knocked something out of place off-roading... aftermarket tranny cooler is a must sounds like it maybe getting hot... check fluid.... high rmps suggests low gear.... check the button on the shifter... for normal driving it needs to be off... also search in the garage and general forums for tranny related topics... many discussions have gone on.... Link to comment Share on other sites More sharing options...
blackpath94 Posted February 27, 2005 Author Share Posted February 27, 2005 (edited) the button is off... i dont think its totally got to do with the fluids.but ill check them anyway. it could be more electrical. like i said it works fine after i turn the car off, then turn it back on. Edited February 27, 2005 by blackpath94 Link to comment Share on other sites More sharing options...
94extreme Posted February 27, 2005 Share Posted February 27, 2005 well, maybe some electical connector or something is loose.. Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 27, 2005 Share Posted February 27, 2005 Use this webpage on my forums to run diagnostic tests on your transmission and positively confirm what the problem is. http://wd21forums.damagedreality.com/phpbb...wtopic.php?t=17 Link to comment Share on other sites More sharing options...
blackpath94 Posted February 27, 2005 Author Share Posted February 27, 2005 ok will do Link to comment Share on other sites More sharing options...
