Rear wiper wont stop
WyKi
Hey guys as title states, my rear wiper once activated wont stop unless I remove the fuse in the fusebox, I took the switch out and cleaned it up and nothing, thing is when I remove the fuse the wiper stays in the 'on' position/resting on the glass and doesnt return to its base pn the door. Any ideas on how to fix this? Thanks
Sounds like the contacts inside that are supposed to open when the wiper goes "home" aren't doing their job. I would probably take the motor apart and look for any obvious problems inside. Could be something simple.
