PINION Posted May 19, 2015 Share Posted May 19, 2015 direct swap, bolt pattern is same Link to comment Share on other sites More sharing options...
nunya Posted May 19, 2015 Share Posted May 19, 2015 Are you asking or telling? If asking, yes all r50s have the same 6x5.5 lug pattern (same as a wd21, though stock r50 wheels would have issues on a wd21 due to back spacing differences). I believe some pre-facelift r50 wheels won't fit on post-facelift due to brake clearance but larger later wheels should have no problem clearing smaller brakes. If telling, it may be a post more fitting for this thread which is a pinned thread about wheels/tire size/etc for r50s http://www.nissanpathfinders.net/forum/topic/19867-max-tire-size-vs-lift-kit-used-vs-custom-or-oe-wheels/page-10?do=findComment&comment=752576over making a new thread 1 Link to comment Share on other sites More sharing options...
rick88ss Posted May 19, 2015 Share Posted May 19, 2015 Pics or it didn't happen. LOL Link to comment Share on other sites More sharing options...
Precise1 Posted May 19, 2015 Share Posted May 19, 2015 Are you asking or telling? If asking, yes all r50s have the same 6x5.5 lug pattern (same as a wd21, though stock r50 wheels would have issues on a wd21 due to back spacing differences). I believe some pre-facelift r50 wheels won't fit on post-facelift due to brake clearance but larger later wheels should have no problem clearing smaller brakes. If telling, it may be a post more fitting for this thread which is a pinned thread about wheels/tire size/etc for r50s http://www.nissanpathfinders.net/forum/topic/19867-max-tire-size-vs-lift-kit-used-vs-custom-or-oe-wheels/page-10?do=findComment&comment=752576over making a new thread x2 but I thought the difference was the 2001 year because of the VQ motor and towing rating? I believe some people have ground clearance on the caliper and put on 15" wheels, but your mileage may vary. I know it has been talked about in threads... B Link to comment Share on other sites More sharing options...
PINION Posted May 19, 2015 Author Share Posted May 19, 2015 cut off is 05, lug pattern change, will post pics. Link to comment Share on other sites More sharing options...
nunya Posted May 20, 2015 Share Posted May 20, 2015 Ok, so this is a "confirmation" post. Use the linked PINNED post already covering this topic to keep info in one collected place. I am closing this thread. Link to comment Share on other sites More sharing options...
