jyeager Posted February 17, 2015 Share Posted February 17, 2015 FYI in case anyone is interested. I know they aren't the most awesome winches...But they've been improved over time and some folks give them a decent review and considering the price.... Harbor Freight is selling a 12,000lb winch for $300 right now. http://www.harborfreight.com/12000-lb-off-road-vehicle-electric-winch-with-automatic-load-holding-brake-61256.html use coupon code 52969012 for $100 off to bring it down to $299.99. That's only good to 2/28. Link to comment Share on other sites More sharing options...
Rebelord Posted February 17, 2015 Share Posted February 17, 2015 For the price they work. Its like $25 more to add a 2yr warranty on it. I know several people that run these. The relay box. Open it make sure the board is actually screwed tight and the ground is good. Common on them. Also seal it good. Doesn't come sealed from factory. Other than that they work. In long hard pulls. Sometimes will over heat the relays. Let it sit and can continue. I know a guy who had his long enough. He turned it in under warranty for a new. Even though it wasn't broken. No questions asked it was swapped. Paid for the warranty on the new one. It has pulled me out in some binds. May not have that fancy three letter name. But will get you out a bad spot. Sent from my Moto X Link to comment Share on other sites More sharing options...
mickyficky Posted February 18, 2015 Share Posted February 18, 2015 Can these mount to a wd21 with a standard bumper? Link to comment Share on other sites More sharing options...
Precise1 Posted February 18, 2015 Share Posted February 18, 2015 Only if you want the weight to tear the bumper off first time you hit a bump... Seriously, no, not even close. You need a specific built winch bumper. B Link to comment Share on other sites More sharing options...
