chapter Posted February 18, 2005 Share Posted February 18, 2005 I have a path 90. When I brake at high speed, the truck pull the right... Any idea about the cause of that?? By the way, my spark plug have about 50000km, is it time to change them? I ask that question because it's a pain in the hiney each time I go the garage to change the spark plug. They have problem to remove them and my fear is they broke one in the engine... So is is possible to keep them until 75000km? I have 370000km on the truck and I planning to change next year.... Snif (( Link to comment Share on other sites More sharing options...
94extreme Posted February 18, 2005 Share Posted February 18, 2005 could be all kinds of things. you need to inspect the brakes first and see what the deal is... you should inspect all of your suspension while you're at it... same on the plugs... pull a couple out and see their condition... look in your OM to see schedule of maintenance and follow it closely... Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 19, 2005 Share Posted February 19, 2005 One of the front calipers is probably sticking or the slide pins needs to be greased so it moves freely. Also check your alignment and steering components for wear and looseness. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted February 19, 2005 Share Posted February 19, 2005 I've had serious sticking issues on 2 sets of caliper/pads where both pulled to the passenger side, although I really wouldn't know what to check. Unfortunately, both sets were pretty spontaneous (or not- Midas sucks!) and died on the spot. Could also be alignment, and that's a simple and cheap fix. Link to comment Share on other sites More sharing options...
dkpath96 Posted March 1, 2005 Share Posted March 1, 2005 I had a nasty grinding noise at low speeds coming from the right wheel, which was present with or without brakes, and was diagnosed as a bad caliper and rotor. I replaced the rotor and got new pads but the garage said the caliper looked fine. Well, it doesn't grind anymore- it squeals when I apply the brakes, however, still from the right side. I am assuming I need a new caliper, correct? Can I replace one caliper and not the other? Link to comment Share on other sites More sharing options...
94extreme Posted March 1, 2005 Share Posted March 1, 2005 calipers may look fine but not work... i am guessing you put in new bearings when you changed your rotor, right? squeling could be almost anything still Can I replace one caliper and not the other? breaks are one of the most important components of your tk... i wouldn't..why skimp on being alive?... i've always done both sides at the same time... but you gotta do what you gotta do... i know what it is to live on v. little... Link to comment Share on other sites More sharing options...
Guest ksakella Posted March 3, 2005 Share Posted March 3, 2005 Definently check the breaks. Frozen caliper is likely the problem. Check the wear of the pads...they should similar amount of wear, if they don't replace them and grease the calipers and pads (you should wipe down and grease all the contact areas). Then check them after a few weeks or if the squeeling comes back. Breaks make noise sometimes even if they are fine. A friend asked me to help him out on his car becuase of some annoying squeeling, and it turned out that he just had a lot of breaks dust collecting between some parts. We hosed it down dorve it around, and presto...silent breaks! I like doing most of the car fixin at home, because I like to save money but more importantly, see what's happening with my pathy first hand. Breaks are not bad, and neither are the spark plugs. It's all about the right tools for the job. Universal joint and extension for the #6 plug (all the way in the back) and plain extension for the rest. Good luck! Link to comment Share on other sites More sharing options...
