Valve Noise after a timing belt job.
Wretchasketch
I just got everything back together after installing a new timing belt. My chain wrench slipped off the can sprocket when removing the center bolt. I'm afraid this is the result. Is this valve noise I'm hearing?http://www.banjohangout.org/myhangout/music.asp?ID=11429
(if this takes you to a page of banjo tunes, scroll down to the one that says Pathfinder motor.) Thanks:)
Edited by Wretchasketch
Well, it is hard to tell from the recording, it just isn't like being there...
Have you used a mechanic's stethescope or metal rod (long screw driver) to try to pin point the source?
So, one of the cams rotated when you removed it's pully? Did you move it back?
When you put the new belt on, the cam pulleys were indexed to the reference marks, and the tooth count between the cam pulleys and the sam/crank pulley was 40 and 43? That should mean everything is lined up...
Did the old belt break, or was this a maintenance job?
How long has it been sitting, could one of the lifers have drained or collapsed?
It seems to idle smooth other than the noise, could you still be having (dizzy) timing issues?
