Coils for sub frame drop without ac coil
AkPrecision
Hi everyone i think i have decided the lift im going to do is the subframe drop but without the ac coils in front. I may at the same time use ome.5" lift coil in front but not sure yet. But does anyone know which set of coils will work in the rear without the ac coils up front? I want it to either be level or have a slight rake to the rear. Just dont want the rear higher than the front. Taxes are coming in soon so its time to do it. Any help is appreciated
There are a few posts on it, but if you're thinking about the KRFabs kit, check their FAQ for details about their spring adapter for using modified (cut) WJ lift coils. I have a smaller SFD and just use 2" spring spacers on the rear OME springs (OME springs up front with 2" of strut spacers), produced a small rake to the front (my preference so it sits level when loaded up at about 250lbs).
