Driver's side exterior door handle
Rooster67
I did mine last week, took about 25 mins because I forgot how I did the other. The passenger side only took 15 minutes the first time. Be careful if your door panels are getting soft/old. The push pins ripped through the particle board on my passenger side on about 4 of them.
I bought a plastic one off Rockauto, which was marked for a Sentra (they swore the part # was the same) and didn't fit until I switched mounting plates with my old one. Then the other handle snapped and I replaced both with new metal ones from eBay, which bolted right up. The install's not too bad when you've got the right part. I think I spent more time fighting (and then repairing) the fiberboard panel than I did on the door handles. IIRC I ended up rolling the windows down to remove the panels, rolling them back up to get at the handle, then rolling them down again to put the panels back on.
