recirculate/vent lever opens at speed
Cuong Nguyen
IIRC you can see that door pretty well if you take out the glovebox door, which would let you see if it's moving all the way. I haven't run into this with mine; it's got a fair bit of resistance behind the levers. Maybe there's a little tension spring or something that's gone?
