EGR delete
ebayfish
Pros... more engine bay space and less carbon buildup in the intake manifold (virtually none if you run a catch can on your Pcv valve as well).
Cons slightly higher combustion temperatures due to the lowering of inert gases in the combustion air charge and maybe a slight decrease in fuel consumption due to a small amount of fuel being sent through the engine to re burn.
Edited by Nefarious
Pretty much sums it up.
Well, here's a good explanation of the egr operation in our engines:
http://www.tuneruniversity.com/blog/2012/05/dont-block-or-remove-the-egr-valve-its-saving-you-money/
The guy does a far better job explaining how it effects the engine than I could.
Note that he is in agreement with everyone else I've read with expert engine tuning knowledge.
