Stupid Dome Light Sensors
ebayfish
All my dome light sensors work except the only one that's constantly used. I grabbed 2 new sensors from the junk yard today, both with rubber still intact. I tried both sensors & still no dome light when the driver door is open.besides the sensor itself, is there a common place when this becomes unplugged/fails? The door ajar light does not come on with for that one door.
The switch grounds to the sheet metal of the door jamb IIRC, so I would start by checking that the bolt hole is clean. If that doesn't do it, jumper from the switch connector to body ground to rule out a problem with the switch itself. If neither of those do it, well, you're gonna have to pull the pillar trim and figure out where that wire's come loose.
