Idler Arm
ebayfish
I'm about to swap a 2wd setup on my truck. I have all the parts but the pitman arm. I ordered a MOOG idler arm, but it is construed rather differently from the old one. It almost looks like a ball joint instead of a bolt shaft. Anyway, its not going to work with the AC idler arm brace I ordered. What are the better brands that can be used with this brace that I should swap this Moog for? The Moog arm for a 2000xterra looks similar, anyone tried it?
This link is for the pathfinder idler arm, rockauto shows a different part number between the 2 and 4 wd for the hardbody, but only shows this one for the pathfinder, both the 2 and 4 wheel drive one's look the same
http://www.rockauto.com/catalog/moreinfo.php?pk=493175&cc=1211993
Edited by ahardb0dy
