rear track bar
PINION
The ac springs definitely do some settling, when I first installed my medium duty ac's in my 01, I had just under 2" of lift (oem springs were still in great shape, only had about 70k miles), after about 10k they were down to about 3/4" lift from previous stock height. Give them some time to come down. As for centering the wheels in the wheel well (front to back), Rugged Rocks makes some very nice adjustable upper and lower links.
Remember that as your suspension compresses, the axle will be swinging up and back. After you recenter it at ride height, you might hit the back of your wheel well or fender lip when you compress the suspension.
Nonetheless, to recenter, you could make your own longer control arms. Pretty easy and reasonable cost too.
