ebayfish Posted October 14, 2014 Share Posted October 14, 2014 I was about to order parts for a wheel/tire upgrade. Just to be sure, is the center bore of the rim 100mm to clear the hubs? Are the lug studs 12x1.25? Link to comment Share on other sites More sharing options...
hawairish Posted October 24, 2014 Share Posted October 24, 2014 Not sure about the minimum center bore, but yes, the lug studs are M12x1.25. Link to comment Share on other sites More sharing options...
WD21colorado Posted October 24, 2014 Share Posted October 24, 2014 iff i do remember correctly i think i was reading somewhere when someone said that the bore size for the pathfinder is a 100mm Link to comment Share on other sites More sharing options...
V8path Posted October 25, 2014 Share Posted October 25, 2014 I was about to order parts for a wheel/tire upgrade. Just to be sure, is the center bore of the rim 100mm to clear the hubs? Are the lug studs 12x1.25? bolt pattern for the wheels is 6 x 5.5 (or 6 x 139.7mm) depending on the upgrade, there are varying offsets and backspacing that should be taken into consideration Link to comment Share on other sites More sharing options...
