Maf sensor upgrade
thorpe991
So iv been reading and read that a n60 maf will give you better flow
Iv searched to answer a few questions i have but can't find the answers
Which cars have the n60 Maf
Is it a simple plug in up grade
Will it send any codes on my stock 3.3 ecu
I believe N60 is Maxima, like R50 is your year Pathfinder. My understanding is that it will not work the same as the stock one, so the computer has to be swapped/modified to work with it. Kinda doubt it would be worth the trouble on a stock motor.
It doesn't really matter what year is is. Slartibartfast is right, when you change the maf, it's changing the input the computer sees, which means it can't figured out the air/fuel mixture that the car needs which means it will probably run like ceap crap, assuming it's a direct swap in, which I doubt, because the current maf already fits fine with the stock intake. And even if it does flow better it's going to hit the stock throttle body and be limited right back down to near stock floe flow maybe a few percent more, which on our cars, won't even be noticeable.
-Kyle
