violent shaking
Guest eaj
:help: -bounce-
Help, between 25 and 40 ish mph my 95 pathfnder (5 speed) begin o shake, otherwise seems fine at other speeds
help in diagnosis - O2 sensor, tie rods, Power steering, clutch plate??
Thanks
eaj
Jack up one front wheel, grab it and see if you can move it side to side or up and down a lot. If so, you have worn out steering components and should replace them asap. Depending on the severity of the shaking it could be that your tires are out of balance. Try to find one of those national tire chain stores that offer free inspection and get them to diagnose it for you.
:confused: seems to be front to back
ran thru the disgnostics - all is well there so must be something mech.
odd...
eaj
:confused:
:shrug: had all tire balanced today, still violent shaking,
at tires plus, they looks at the steering tie rods, etc, all they could come up with is that the CV boot was missing - could this be it?
again the shaking is intermittant 30 to 45 mph
could it be in the tranny
further diagnosis???
The missing boot wouldn't do anything in normal driving.
You said they checked the tie rods, etc...what's the etc? Did they check if any of the rims were bent?
I highly doubt it would be the tranny, it would stop working before it would cause vibration like that.
THe guys at tires plus were pretty nice and surprising;ly honest
have an appointment tommorrow at a full service garage
will mention all the coments herein
stand by...hopefully not a cashectomy
Thanks -alcohol-
could also be the TPS. if it has a worn spot (30-45 is about where it would show up too) it would send the wrong voltage signal to the computer, basically making it fight itself and making the mixture too rich, then too lean and back again. most of the time, it won't set a code... as far as the computer is concerned the signals are plausible, just not right.
is it a manual or AT? if it's AT then that's a whole new set of possibilities.
