Djfob Posted August 17, 2014 Share Posted August 17, 2014 Mounted 15" rims with 31 Bfg ta ko. The rims just clear the larger brake calipers. My question is how close is too close. I might have 1.5-2mm of clearance between outer edge of caliper and inner diameter of rim.Do brake calipers expand much with heat? Link to comment Share on other sites More sharing options...
ferrariowner123 Posted August 17, 2014 Share Posted August 17, 2014 2mm should be enough, according to DVW it's when you put new pads that it becomes an issue. -Kyle Link to comment Share on other sites More sharing options...
CDN_S4 Posted August 17, 2014 Share Posted August 17, 2014 you can always add a 5mm spacer. I've run spacers on all my cars so far and never had any issues. Especially not when it's only 5mm. Maybe 20+mm will more likely cause issues due to increased stress on components, but 5 and below should be no issue. Link to comment Share on other sites More sharing options...
kdj Posted August 17, 2014 Share Posted August 17, 2014 I tried my 15" spare on my '03 with new brakes.and they turn easily by hand but do touch. They might clear if the rim wasn't packed with mud and rust but I plan on grinding a little of the calipers before installing the tires for the winter. I'd rather grind them down a bit than add spacers. Link to comment Share on other sites More sharing options...
Djfob Posted August 18, 2014 Author Share Posted August 18, 2014 (edited) Measured with a feeler gauge, at it's closest point there's 1mm of clearance. Tight but so far it drives without touching. These are 15s off a 96 Tacoma for future reference. Edited August 18, 2014 by Djfob Link to comment Share on other sites More sharing options...
