Automatic Shift Knob
Jacob211
I might have an idea! if you take off the shifter there's a plunger for the shift lock if you tape down the plunger then you basically eliminate the shift lock. And then put on anything you want after modifying it to fit the square tube. Then you can mount the overdrive button to the square tube. Still taking ideas and thoughts.
