new heads for my 93 have a different style distributor, need help
DsR50
Ok so I pulled the heads from another pathfinder but am unsure of the year but I'm pretty sure it was in the 90-95. I've already installed them and just found that the way the distributor mounting is a little different. I can make a little bracket to make it work but I want to know if I might be missing a bracket from the donor or if I might be missing a bracket from the donor or if that distributor from the donor would work on my 93
There's a plate that bolts to the head (2 bolts iirc) that the distributor actually bolts to and has the correct angle for the distributor mout (mpfi and TBI have different distributors and use different mounting plates, I had to change mine when I swapped from TBI to mpfi style). Do you have this plate? I'll look to see if I have a pic of one (I know I have spares somewhere from pulling enough spare dizzys)
