Norcal200486 Posted July 9, 2014 Share Posted July 9, 2014 Ok guys and gals I have a 1990 pathfinder I was out wheeling the other day and got stuck in the sand put the truck in park but the display on dash still reads in 1st gear. Turn off truck then it wouldn't start had to jump over the starter but still says it's in 1st gear. Move the gear selector to D and has no power to any of the wheels. just had trans rebuilt less then 10,000 miles ago. It's an automatic any advice or similar problems would be great! Thanks Link to comment Share on other sites More sharing options...
Precise1 Posted July 9, 2014 Share Posted July 9, 2014 The shifter is cable activated to the tranny, so make sure that is hooked up properly. It makes sense that the truck didn't want to start in gear... Did the tranny get hot in the sand? What is the fluid like (just covering all bases)... B Link to comment Share on other sites More sharing options...
Terranovation Posted July 9, 2014 Share Posted July 9, 2014 Yeah they only start in either P or N Link to comment Share on other sites More sharing options...
Norcal200486 Posted July 9, 2014 Author Share Posted July 9, 2014 Fluid is normal... And I know it only starts in P or N but the shift is in park but the electric display on panel says it's in 1st gear. Regardless of what position you have the shifter in. Link to comment Share on other sites More sharing options...
Terranovation Posted July 9, 2014 Share Posted July 9, 2014 Wow that's a weird one, so it's in P and you've definitely disengaged 4wd mode? Because I know if mine isn't properly disengaged the gear won't shift into D. Link to comment Share on other sites More sharing options...
Norcal200486 Posted July 9, 2014 Author Share Posted July 9, 2014 Ya the shifter is all the way up to park but the display on the cluster (dash) says it's in 1st no Matter what position the actual shifter is in. But none of wheels seem to have power to them. If I burnt up the tranny I should still have R right? Link to comment Share on other sites More sharing options...
Terranovation Posted July 9, 2014 Share Posted July 9, 2014 Is it out of 4wd drive mode though? Try putting it in N then move the 4wd stick to 2L that should get it out of 4wd then put trans into D. Link to comment Share on other sites More sharing options...
Norcal200486 Posted July 9, 2014 Author Share Posted July 9, 2014 Ya it's out of 4wd. Link to comment Share on other sites More sharing options...
Norcal200486 Posted July 10, 2014 Author Share Posted July 10, 2014 So tore into it and found the neutral safety switch to busted replaced that from the wrecking yard for 10 bucks. However didn't fix the problem. Dropped the trans pan everything looked cherry. Drained the transfer case and found burnt oil and huge metal shavings. whelp that's where the problem is. Link to comment Share on other sites More sharing options...
Slartibartfast Posted July 11, 2014 Share Posted July 11, 2014 Yikes! That's not good, but at least you know. I'm not sure how it would cause the stuck gear indicator, though. Link to comment Share on other sites More sharing options...
