txpath4x4 Posted June 6, 2014 Share Posted June 6, 2014 Ok so I installed an electric fan that was supposedly rated for the Pathy, yeah the Texas heat claimed another victory. So back to mechanical it is( with a new fan clutch) Link to comment Share on other sites More sharing options...
Kingman Posted June 6, 2014 Share Posted June 6, 2014 Villager/Quest or 3.8L Taurus fans work very well. I have the Nissan fan and sitting in traffic in 100* weather low keeps it plenty cool. Towing a trailer up hills in 90*+ isn't an issue either. 1 Link to comment Share on other sites More sharing options...
vagabond Posted June 6, 2014 Share Posted June 6, 2014 On my 88 I'm running the earlier Maxima fans with the metal frame, also the the temp sensors that fit in the bottom of the max rad. I placed the temp sensor in the metal tube in the upper rad hose it turns on the low speed fan at 190 degrees the high speed fan I have hooked to a switch on the dash. The 94 I did the same way and have had no problems with either one. The fan shroud fits the pathy rad almost perfect, I think I have some pics of the installation on here somewhere. 2 Link to comment Share on other sites More sharing options...
theexbrit Posted June 7, 2014 Share Posted June 7, 2014 I originally had 2x12" fans in an aluminum shroud that only covered 2/3rds of the rad & I always had over heating problems on long, slow hills. I have since fitted a Taurus 2 speed fan, a Dakota Digital controller & an OEM shroud, nary a heat problem now!! 1 Link to comment Share on other sites More sharing options...
Canadian Posted June 9, 2014 Share Posted June 9, 2014 Definetely need more than one 12" fan for our carsI run 2 12's with no shroud and have no issues Link to comment Share on other sites More sharing options...
