Interesting Idea in regards to Keyless entry, What is your opinion
i had an idea that im unsure would work, my 97 qx4 has the older style remote, however i was at the junk yard today and found a 97 pathy and a 02 pathy and while look at the control box under the driver seat it appeared that it used the same wire connectors as the 97, my question is can we upgrade to the newer box and will it work. i like the flip keys they make for the new keyfob
Hmmmmm interesting.
Well if I were in your shoes I'd grab the 02 remotes and module and see if it works, worst thing that happens is a blown fuse.
What exactly is different between the old and new Gen?
-Kyle
I bet you could program the newer remotes to your truck. Just find the learning procedure, and give it a go.
the newer remotes have a different fcc id, hence the reason for the brain box swap
