Just Does your sunroof seem loose?
ahardb0dy
Just a heads up as I just told another member that did not know this, if your sunroof is loose or lifts when driving, you can adjust the latch so it closes tighter.
Just press the buttons near the latch like you were going to remove the glass and take the metal part that bolts thru the glass out of the latch, than remove the one Phillips screw that holds the black plastic cover onto the latch, under the plastic cover you will find 2 bolts that hold the latch part to the roof, the holes in the latch are oblong so you can loosen the bolts and move the latch, to make it close tighter you move the latch part towards the rear. After you do this, put the cover back on, and clip the glass part of the latch back into the body half, and try closing the sunroof, it should be tighter.
