brc19761 Posted January 27, 2014 Share Posted January 27, 2014 Hi, I usually post in the1987-1995 pathffinder forums. I am looking to buy a 2007-2012 Nissan Pathfinder, but still keeping my old pathfinder. I have been mostly shopping online for over two weeks and just hit the dealerships this weekend. What does the Fe + stand for on some of the Pathfinders. I just knew if I googled it I would find the answer, but I could not find it anywhere on the net. I am thinking it may have something to do with types of fuel. Thanks, brc Link to comment Share on other sites More sharing options...
Pav Posted January 27, 2014 Share Posted January 27, 2014 Rob would be the expert here...but from the limited searching I did because you made me curious to find out is that FE stands for Fuel Efficiency. Nissan came out with FE and FE+ as a designation for their vehicles that got slightly better fuel economy in '09. It seems that FE+ Pathfinders are all 2WD. If you are looking at that model of Pathfinder you should also try and take an Xterra out for a spin. Its not as fancy inside but same mechanicals and takes regular fuel instead of the Premium they suggest for the Pathfinder. I used to have an '05 and it was a really capable truck...you can toss just about anything into the back of it. 1 Link to comment Share on other sites More sharing options...
brc19761 Posted January 28, 2014 Author Share Posted January 28, 2014 Thanks for the response. I test drove the truck yesterday and you were exactly right. It stood for Fuel Efficiency +. The salesman said that the motor was designed to with direct injection for better gas milage. Link to comment Share on other sites More sharing options...
Alkorahil Posted January 30, 2014 Share Posted January 30, 2014 Rob would be the expert here...but from the limited searching I did because you made me curious to find out is that FE stands for Fuel Efficiency. Nissan came out with FE and FE+ as a designation for their vehicles that got slightly better fuel economy in '09. It seems that FE+ Pathfinders are all 2WD. If you are looking at that model of Pathfinder you should also try and take an Xterra out for a spin. Its not as fancy inside but same mechanicals and takes regular fuel instead of the Premium they suggest for the Pathfinder. I used to have an '05 and it was a really capable truck...you can toss just about anything into the back of it. Pav is correct! Fuel Effecient and Fuel Effecient Plus Link to comment Share on other sites More sharing options...
