95 Pathfinder Exhaust Stud
Jimmie
They are M8 x 1.25. I used 30mm grade 5 bolts with a flat washer and lock washer. Perfect length on my aftermarket headers. Everything from Nissan was special order and I didn't want to wait for it to come in. Bolts work fine, however studs are nice for lining up your manifold.
I just did mine and used this thread for info, however some of it may be incorrect.
http://www.nissanpathfinders.net/forum/topic/31230-exhaust-bolts/?hl=%20exhaust%20%20studs
One of the posters in this thread posted up this info
PN 14037-V5005 - Lock Washer
PN 14039-W1500 - Nuts
PN 14065-V5004 - Manifold studs
They also posted up 40mm bolts as an option, which may work on factory manifolds with the thick washer, however they bottomed out before tightening up on aftermarket headers with thin flat washer and locks.
When I gave these part numbers to my local dealership they told me these studs are for a 95 quest. Are they the same as the turbo 300ZX? No idea, but either way they were special order.
I hope this helps, I know I got tired and searching threads and went for the first info I could find.
