urimashe
How To: Replace Valve cover Gaskets.
Found this video on youtube. thought it might be helpful for everyone out there.
should be helpfull
I always say to try tightening them first, most of the time it is all that is needed. ;)
Wish it was that easy !!
You shouldn't need any adhesive to hold the gasket to the valve cover, the valve cover has little metal tabs that hold the gasket in place, I just did my pass. side and it had them. I guess my pass. side wasn't leaking as the cover was stuck on so good I had to pry on it to get it off, even after I realized I had missed a bolt !!!
should be helpfull
On the video at the 3:40 area he shows " once U get all the wires outta the way" ! YA ..how DID U get the those wires outta the way? Hhmmmm? Show me how U disconnected those from the valve cover wudja? haha
Ok, that guy is annoying. I couldn't watch the whole thing. No need for any epoxy on the gasket. It will stay in the valve cover. While you are there replace the rubber bolt grommets also.
