Karmann Posted November 26, 2013 Share Posted November 26, 2013 So I just bought, without thinking quite enough, some Jeep Grand Cherokee springs for the rear of my pathy. They fit and lifted a WD pathy 2" in the rear. Will these work on my R50? Link to comment Share on other sites More sharing options...
Bubbley11 Posted November 26, 2013 Share Posted November 26, 2013 I think you'd be the first, IIRC. Cut the pigtails and find out it it fits then see the result Link to comment Share on other sites More sharing options...
Karmann Posted November 26, 2013 Author Share Posted November 26, 2013 I think you'd be the first, IIRC. Cut the pigtails and find out it it fits then see the result Uh oh. Well they're already cut, so I'm good there. Just hoping I didn't make a big mistake. Link to comment Share on other sites More sharing options...
Karmann Posted November 27, 2013 Author Share Posted November 27, 2013 Ok I've been researching. Does anyone know the Outside Diameter, Length, and Coil Thickness of the stock rear springs of a facelift R50? The same info on an OME or AC would be equally helpful. PS. Yes I did search the "Using Non-Pathfinder Specific Coils to Obtain Lift" thread, and it offered not quite the info I'm looking for. Link to comment Share on other sites More sharing options...
Karmann Posted November 27, 2013 Author Share Posted November 27, 2013 Anyone? Link to comment Share on other sites More sharing options...
Rick13 Posted November 27, 2013 Share Posted November 27, 2013 Well, you definitely won't be the first with WJ rear coils. I'm on my second set, but yeah, they can work with a little customization (modified seat/adapter). Something like this? I think the estimated lift heights aren't all correct and I'm sure the prices aren't the same (I did this over 3 years ago): Link to comment Share on other sites More sharing options...
Kyle94 Posted November 27, 2013 Share Posted November 27, 2013 I can measure my ac coils when I get home. They seem bigger than wd coils though. 1 Link to comment Share on other sites More sharing options...
96Pathfinder4x4 Posted November 27, 2013 Share Posted November 27, 2013 (edited) You need adapters. The diameter is bigger on the bottom. Maybe top too, but I trimmed mine to fit the cups and for the truck to sit level. They were 6" WJ (Grand Cherokee) lift springs. Krypton Fabs has them for $30. http://www.krfabs.com/product_detail.php?productID=6 The two cups in the top left is what you need. Bolts on and the spring sits around it. You can sort of see them here. Edited November 27, 2013 by 96Pathfinder4x4 2 Link to comment Share on other sites More sharing options...
SkiBumBrian Posted November 28, 2013 Share Posted November 28, 2013 Aww... it'll be the best 22 bucks you ever spent....lol Link to comment Share on other sites More sharing options...
Karmann Posted November 28, 2013 Author Share Posted November 28, 2013 (edited) You need adapters. The diameter is bigger on the bottom. Maybe top too, but I trimmed mine to fit the cups and for the truck to sit level. They were 6" WJ (Grand Cherokee) lift springs. Krypton Fabs has them for $30. http://www.krfabs.com/product_detail.php?productID=6 The two cups in the top left is what you need. Bolts on and the spring sits around it. You can sort of see them here. Hmm, I may do that, I'll see how they fit on the upper spring perch. Not sure if they're wj or zj Hahaah Edited November 28, 2013 by Karmann Link to comment Share on other sites More sharing options...
Karmann Posted November 28, 2013 Author Share Posted November 28, 2013 I can measure my ac coils when I get home. They seem bigger than wd coils though. That would be wonderful! Link to comment Share on other sites More sharing options...
thorpe991 Posted October 28, 2014 Share Posted October 28, 2014 (edited) im looking to sfd my pathy 3" make my own spacers buy the adapters and panhard drop and brake lines from krfab would these coils work (http://www.rustysoffroad.com/jeep-suspension/jeep-coil-springs-spacers-accessories/jeep-wj-grand-cherokee-99-04-coils-springs-coil-spring-spacers/rustys-coils-wj-4-5-rear.html) have a 1.5"spacer in the front now so it should equal to level Edited October 28, 2014 by thorpe991 Link to comment Share on other sites More sharing options...
Yendor Posted November 10, 2014 Share Posted November 10, 2014 Now if JGC springs fit the R50 with a seat adapter, would I be able to fit the Calmini 3" lift spings out of my 95? Link to comment Share on other sites More sharing options...
MrJoosten Posted November 12, 2014 Share Posted November 12, 2014 Hey Thorpe991, I just finished doing the krfabs 4" subframe drop + the AC 2" coils, I used 4" Wj coils in the rear with krfabs adapters and 1" spacer. I think if you were to get the 4.5" coils for the rear with a 3" front spacer you'll have a really bad rack. 1 Link to comment Share on other sites More sharing options...
dustinp Posted December 2, 2014 Share Posted December 2, 2014 http://i737.photobucket.com/albums/xx12/perreaultdustin/0820140345a_zpsylt9tazp.jpg Just the top adapter Link to comment Share on other sites More sharing options...
green180 Posted December 3, 2014 Share Posted December 3, 2014 Hey dustinp what are the dimensions of the spacer under the blue spring cup, I need to build a 2 inch spacer for mine, I have jgc springs in the rear already on my r50, thanks Link to comment Share on other sites More sharing options...
Jesus Posted June 8, 2020 Share Posted June 8, 2020 Hi Karman: i need a drop sub frame kit 6" for nissan pathfinder 1996 se 4x4. please send me via email how much this kit wiht the shipping from puerto rico zip code 00956. thanks for all. Link to comment Share on other sites More sharing options...
Guest Posted June 8, 2020 Share Posted June 8, 2020 4 hours ago, Jesus said: Hi Karman: i need a drop sub frame kit 6" for nissan pathfinder 1996 se 4x4. please send me via email how much this kit wiht the shipping from puerto rico zip code 00956. thanks for all. You replied to posts from 2013. I believe that user no longer is active. If you want a subframe drop kit, you are looking at $900+ USD Link to comment Share on other sites More sharing options...
BamaQX402 Posted June 8, 2020 Share Posted June 8, 2020 11 hours ago, R50JR said: You replied to posts from 2013. I believe that user no longer is active. If you want a subframe drop kit, you are looking at $900+ USD Or build your own... Link to comment Share on other sites More sharing options...
