LOVELADY Posted October 21, 2013 Share Posted October 21, 2013 I have a 1995 pathfinder and i was wondering if it would hurt my engine if i ran it without my egr valve. I was trying to take it off to clean it the bolt was stuck on there good from the rust and then i turned it and the whole thing broke off. Link to comment Share on other sites More sharing options...
ahardb0dy Posted October 21, 2013 Share Posted October 21, 2013 What exactly broke? Link to comment Share on other sites More sharing options...
LOVELADY Posted October 22, 2013 Author Share Posted October 22, 2013 the metal pipe that runs from the exhaust to the egr valve. The part of that pipe that screws into the egr valve it was rusted to the threads it screws into and when I went to unscrew it it shaped all the threads off the egr valve Link to comment Share on other sites More sharing options...
LOVELADY Posted October 22, 2013 Author Share Posted October 22, 2013 snapped off the threads* Link to comment Share on other sites More sharing options...
ahardb0dy Posted October 22, 2013 Share Posted October 22, 2013 should be able to find a used one at a junkyard, if you were to run the engine with out it you would need to make a plate to block off the opening first anyway. Link to comment Share on other sites More sharing options...
Precise1 Posted October 22, 2013 Share Posted October 22, 2013 i was wondering if it would hurt my engine if i ran it without my egr valve. You could move the vehicle, but I wouldn't drive it any distance, much less try to drive it 'normally'. Not only would it blow extremely hot exhaust gasses into the engine compartment (near items that could melt) but it would confuse the O2 sensor down stream, probably making it run rich. It could be blocked off if there are still threads to do so, but it really sounds like it should be parked until you can source the replacement part. Junk yard parts may be rusted as well (exhaust parts often are) so if you source a new part, try this guy. http://www.nissanpathfinders.net/forum/topic/18653-genuine-nissan-parts/ Great guy, knows his stuff and probably the best prices you can find for dealer parts. B Link to comment Share on other sites More sharing options...
Kingman Posted October 22, 2013 Share Posted October 22, 2013 If you're looking for a free fix, crush the pipe closed down near the manifold, or weld it closed and rock on. Make sure to unplug the EGR solenoid though. Running it like it is is not a good idea like B said. Link to comment Share on other sites More sharing options...
silverton Posted October 22, 2013 Share Posted October 22, 2013 If you decide to replace, blast everything with a good douching of PB Blaster or some other form of penetrant before trying to remove/install. Link to comment Share on other sites More sharing options...
Precise1 Posted October 22, 2013 Share Posted October 22, 2013 Good call, this is usually the case when working on rusty/corroded components. If you're looking for a free fix, crush the pipe closed down near the manifold, or weld it closed and rock on. Make sure to unplug the EGR solenoid though. This will work, but you probably wouldn't pass a smog test/visual inspection that way so proceed accordingly. B Link to comment Share on other sites More sharing options...
LOVELADY Posted October 22, 2013 Author Share Posted October 22, 2013 thanks everyone for the help i can now drive my truck again. Link to comment Share on other sites More sharing options...
