Everything posted by LOVELADY
alright I will let y'all know when I start
thank you all
do I need to do anything with the transmission to make it fit to the engine out of the 1999 pathfinder so it can hook up to my 1995 pathfinder
thank you very much now I have a weekend project thanks and my pathy will be back to life.
I own a 1995 Nissan pathfinder and three months ago the engine started to act weird and kept getting worse so I have decided to just put a new motor in it. My buddy has a 1999 pathfinder with a good motor in it but a body not worth fixing. So I'm wondering if the motor out of the 1999 will fit in my 1995 and mount to my tranny as well.
all fluids are topped off i keep them check all the time
I have a 1995 nissan pathfinder LE and it idles fine but when i put it into reverse or drive it bogges down to 0rpm and barely runs and when i give it gas in drive to go somewhere it sounds like it is going faster then what it is and i can only get up 30 miles per hour and it only makes it to second gear. I would like some help please been doing this for 2 months now and i am ready to stop pouring money into it. thanks.
no I have never replace my distributor cap.
this is second pair of brand new wires I bought and still lighting up
I bought them from O'Reillys auto parts and they where the only brand in stock
on one of them the spark plug and wire touch but the other flashes are on the wire it self
I changed my spark plug wires today and these are still flashing like the old ones and it don't run any better
I looked under my hood last night while it was dark cuz that's when I got home and and while she was running I saw the spark plug wires lighting up just the wires are they suppose to do that and if not could this be the problem
I found something online about what's going on with spark plugs when they look different ways and I found what mine look like and it says that my spark plugs are gapped to big and I need to replace them so I checked them and they are suppose to be gapped at 0.32 and there gapped at 0.40 so could this be my problem
I got my timing belt changed back in march
I also have filled her up 2 different times since this has started so could it still be water and could it be the fuel pump
yes please send pics but would that also cause it to do it even at a stop light and when I'm going to have not enough power to go any where
i changed my spark plugs like two months ago and my wires like a month ago. my fuel filter was changed like 2 to 3 years ago. my air filter looks clean. i also have a snorkel on my pathfinder.
does it still put out a code even tho the check engine light is not on
no after warm up it still does the whole time its running. My check engine light is not on. And I don't know how to check codes sorry.
My 95 LE pathfinder has been acting weird. This was my first car I got her when I was 17 and i am 23 now. I baby her like crazy. So when this started to happen I started to get scared. What she is doing is when i'm at a stand still or in park she is barely running like she is about to die. if i stop at a red light then take off its like she can't go untell she gets a little gas but then she barely goes. Then on a hill she has no power. I just would like a little advice if i can get some because i like to fix her my self but i can't figure this one out. Thank you all the help in advance.
thanks everyone for the help i can now drive my truck again.
snapped off the threads*
the metal pipe that runs from the exhaust to the egr valve. The part of that pipe that screws into the egr valve it was rusted to the threads it screws into and when I went to unscrew it it shaped all the threads off the egr valve
I have a 1995 pathfinder and i was wondering if it would hurt my engine if i ran it without my egr valve. I was trying to take it off to clean it the bolt was stuck on there good from the rust and then i turned it and the whole thing broke off.
