GAS Posted January 22, 2005 Share Posted January 22, 2005 hi all Still sturgling whit the gas milage, I did fill it up whit gas yesterday and 65 Liters went on the tank and the km was only 263 then it is almost 25 L/100KM in city driving in only rear wheel drive it is around minus 5 -7 here now on the selcius scale. What I have done to tray to fix this: New spark plugs K&N filter New Oxygen sensor the truck is just stock on 30" tires and have 176.000 km on it. This is automatic V6 3.0L engine model1990 Does it help to take out the catalyst converter and put just pipe insted ? There is no law in Iceland that tells you to have it in, if the car is older than 1995 Any ideas what to do ? Link to comment Share on other sites More sharing options...
94extreme Posted January 22, 2005 Share Posted January 22, 2005 injector cleaner maybe... ~10mi/gal seems a bit low... if you like to breathe fresh air i'd recommend you leave that catalytic converter on... Link to comment Share on other sites More sharing options...
Precise1 Posted January 23, 2005 Share Posted January 23, 2005 That sounds bad... in the city you should be able to get about 5KM/L easy... Are you a lead foot ?? Does the truck roll freely ? Maybe brakes are rubbing or the universal joints are binding ?? Is the odometer reading correctly ? Something is definitely up !! B Link to comment Share on other sites More sharing options...
wheelmanLS1 Posted January 27, 2005 Share Posted January 27, 2005 Just as a note... since my speedometer is off, so is my odometer. When I calculate MPG, it gives me 18mpg in the city. So maybe it could be the other way around for you? Just a thought. Link to comment Share on other sites More sharing options...
88pathoffroad Posted January 27, 2005 Share Posted January 27, 2005 What octane rating is the fuel you buy there? Just wondering. Link to comment Share on other sites More sharing options...
GAS Posted January 29, 2005 Author Share Posted January 29, 2005 it is 95 okt here Link to comment Share on other sites More sharing options...
90seven Posted January 29, 2005 Share Posted January 29, 2005 Just as a note... since my speedometer is off, so is my odometer. When I calculate MPG, it gives me 18mpg in the city. So maybe it could be the other way around for you? Just a thought. Hehe, you can get away with selling it for lower milage than it is. Link to comment Share on other sites More sharing options...
Guest stormteam Posted February 14, 2005 Share Posted February 14, 2005 Check the air in the tires, it did wonders for me. Link to comment Share on other sites More sharing options...
