Rear Diff
headpeace
Looks the same as my mom's G37's diff plugs. IIRC I used a 10mm drain plug socket. Buy this drain plug socket set from Harbor Freight and use a printable 20% off coupon. It will have the socket you need for both newer and older Nissan drain and fill plugs. Our Pathfinders will use the 13mm drain plug socket.
You might want a 3/8" to 1/2" adapter to use with a breaker bar if the plugs are very tight, too.
