Steering Knuckle Question
Ishikawa91
I am removing the steering knuckle from my '96 Pathfinder. I have removing everything aside from one last thing. There is a wire that plugs into the back of the knuckle. Does anyone know what this is exactly or how to get it off? Its a pretty fat rubber "boot" that is completely stuck. I have tried wiggling and yanking but its on there pretty tight. I will try to post a picture tonight or tomorrow.
I checked the FSM but it didn't mention anything for the steering knuckle.
Thanks guys! It was the ABS sensor. Found it easier to just unplug the clip instead of removing it. The clip was right behind the spring bolted to the inner wheel well.
Does anyone know if I need to remove the stabilizer bar to remove the sway bar links? Mine are completely shot and I thought I might as well change them since I've got everything off already.
