Guest Freaknasty Posted January 17, 2005 Share Posted January 17, 2005 I am wondering what the difference in loss of power is when you add 32 inch tires opposed to 33's? I have a 95 3.0L thanks bros Link to comment Share on other sites More sharing options...
Precise1 Posted January 18, 2005 Share Posted January 18, 2005 Yo FN. Just to be silly I'll state that there is no power loss when switching tire size; the motor runs the same regardless. From there, the 'felt' loss of acceleration is usually whe one increases not decreases tire size when you add 32 inch tires opposed to 33's Did you mean the opposite ? Regardless, the 'power' loss would not be amazing for 1" difference in diameter, but will still be present... B Link to comment Share on other sites More sharing options...
Guest Freaknasty Posted January 18, 2005 Share Posted January 18, 2005 im sorry what i mean is ..if i put on 33's thats alot more "meat" for the engine to push say up an incline i figured power loss would be a good way to describe it but now im thinking maybe not , anyway thats what i meant Link to comment Share on other sites More sharing options...
XerOne Posted January 18, 2005 Share Posted January 18, 2005 well your gas mileage is going to go down since your engine will be working harder to shove your path anywhere Link to comment Share on other sites More sharing options...
Reido Posted January 18, 2005 Share Posted January 18, 2005 going from 32" to 33" you'll have 96.97% of the acceleration you used to have at the same rpm and gear. Just take the ratio of the two tire diameters or radiuses (radii?). 31"/33" = .9394 = 93.94%. This ignores the extra weight of bigger tires which I think you mentioned earlier. I'd guess an extra couple of pounds per tire per inch, so nothing you're going to be able to notice. Link to comment Share on other sites More sharing options...
Precise1 Posted January 21, 2005 Share Posted January 21, 2005 Very well described.... In other words, yes, it will feel like there is less grunt, but .5" radius isn't going to make a huge difference. A better was to look at it is are you ok with the ability of your truck to push 32" tires ? If so, 33's probably wont make you cry, but if it is already lacking then don't go any bigger. Personally, I have 31" tires and would not go any larger with out engine power mods, but then that's just me. Just messing with you on the earlier post; I SORT OF understood what you were asking Bernard Link to comment Share on other sites More sharing options...
GrimGreg Posted January 21, 2005 Share Posted January 21, 2005 It's the width that'll really add to the feel of lost HP. The wider the tire, the larger the contact patch on the ground, the more friction there is between the tire and the ground. Link to comment Share on other sites More sharing options...
Guest Freaknasty Posted January 21, 2005 Share Posted January 21, 2005 im thinking some 32 inch m/t's should be good Link to comment Share on other sites More sharing options...
mtnnate Posted January 27, 2005 Share Posted January 27, 2005 I was having the same debate with myself for a while. I just decided to buy 33x12.50's anyway because they look so good and Pathy's are a little ground clearance challenged in the first place. I've added a K&N with a snorkel (homemade, Ramair) and a turbo muffler so that should have added something in the way of power. You could add cams or gears for the same price roughly. Possibly you could add used Xterra gears for cheap. I'll start looking for some 4.90 XTerra gears next. That will make up the difference! Link to comment Share on other sites More sharing options...
