Slartibartfast Posted May 30, 2013 Share Posted May 30, 2013 My dad's r50 has been making odd exhaust noises, so he took it to a mechanic, and apparently the driver's side secondary catalyst is cracked (common problem but it's out of warranty). We live in an area with no emissions testing, and replacement cats are expensive. Has anyone put a test pipe on an r50 exhaust? Any chance this would throw codes or cause other issues? If so, any recommendations for an aftermarket cat? Link to comment Share on other sites More sharing options...
tdauria Posted May 30, 2013 Share Posted May 30, 2013 Sadly, I have no answers to your questions but depending on how bad the crack is and how desperate you get, you MIGHT be able to get a result using this technique with beer cans and jb weld (if this crack is on the outside surface)... http://jalopnik.com/5949291/how-to-fix-your-exhaust-with-an-empty-beer-can Link to comment Share on other sites More sharing options...
5523Pathfinder Posted May 30, 2013 Share Posted May 30, 2013 (edited) Nissan has a repair kit and its a piece of cake to install. It's not that much either. Talk to Rob(Alkorahil) Edited May 30, 2013 by 5523Pathfinder Link to comment Share on other sites More sharing options...
Slartibartfast Posted May 31, 2013 Author Share Posted May 31, 2013 The beer can repair sounds good to me but I'll check out the patch kit, thanks! Link to comment Share on other sites More sharing options...
Slartibartfast Posted June 12, 2013 Author Share Posted June 12, 2013 Update for anyone else with this problem, my dad took it to a local shop and had both resonators (turns out they're not cats) removed, welded up, and put back in, $150 out the door and it sounds right again. His research suggested that the patch kits don't hold up. Link to comment Share on other sites More sharing options...
