Guest Snell Posted December 31, 2004 Share Posted December 31, 2004 HELP ME PLEASE, my pathy is about 6 feet deep in snow, i dug it out mostly but my clutch has no pressure and i cant get it into any gear. and the clutch now wont pop back up when its pushed all the way in. How can i get my pathy in gear and move it befor it gets run over by a snow plow or towed by sheriffs!!!! Link to comment Share on other sites More sharing options...
statikuz Posted December 31, 2004 Share Posted December 31, 2004 Sorry to state the obvious, but did you make sure there was brake fluid in your clutch cylinder reservoir thingy? Link to comment Share on other sites More sharing options...
88pathoffroad Posted December 31, 2004 Share Posted December 31, 2004 You're either going to have to dig it out and somehow melt all the snow away from the tranny and clutch slave cylinder, or have it towed. That's a pretty obvious one. Link to comment Share on other sites More sharing options...
Guest pathfinderdriver Posted December 31, 2004 Share Posted December 31, 2004 Where are you located? Link to comment Share on other sites More sharing options...
statikuz Posted January 1, 2005 Share Posted January 1, 2005 Well yeah, if its really 6 feet deep in snow. Link to comment Share on other sites More sharing options...
Reido Posted January 1, 2005 Share Posted January 1, 2005 You should be able to get it into first or reverse even if your clutch won't disengage. The engine can't be running though. If it doesn't go in to first or reverse try some other gears to hopefully move something enough so you can get first or reverse. If that doesn't work just turn the key real quick to blip the starter and move some gears a little more. Once you get it into 1st or rev you can start it up in gear but you'll be moving as soon as you turn the key. Link to comment Share on other sites More sharing options...
Guest Snell Posted January 1, 2005 Share Posted January 1, 2005 (I am a dork for trying to use profanity here), im screwed. im in tahoe ca i think the cold freezes the tranny and clutch , cause the truck is basicly nearly high centered on snow. i could probly move it if i could get it in a gear. not sure what to do, i can put it in any gear with the car off, but doesnt seem to start when i try to start it in first or reverse. anyway i can some how forse it into firse and drive in home one block away in first? Link to comment Share on other sites More sharing options...
statikuz Posted January 1, 2005 Share Posted January 1, 2005 Sorry to state the obvious AGAIN, but don't you have a neighbor or someone who could help you pull it out of the snowbank and then at least PUSH it home? Link to comment Share on other sites More sharing options...
94extreme Posted January 14, 2005 Share Posted January 14, 2005 to start your truck in gear you have to depress a button located next to the cruise control on/off button (can't recall what it's called;) left of the stearing wheel.. Link to comment Share on other sites More sharing options...
jj big shoe Posted January 14, 2005 Share Posted January 14, 2005 It's the "interlock" button. I think I read somewhere it's for bypassing the clutch pedal safety switch. You could try running the engine for a while. The heat might help unfreeze everything. Just make sure to clear the snow away from the tailpipe. Be careful because with that much snow under you, carbon monoxide could build up under your truck and kill you while you're waiting for things to thaw. Good luck. Link to comment Share on other sites More sharing options...
