Can someone identify this part
jayjay6888
The positive battery terminal has three cables attached to it: the largest cable goes to the starter motor, and the two smaller cables attached to the "red harness" go to the main fusebox (that is, the rest of your truck's electrical system).
It can be done, I changed my post set up from top post to side mount post so I could hook my winch up to the top mounts on my yellow top battery. Just buy the new post and transfer the wires over... not that hard.
Edited by muddfildvaynes
Battery part was obvious just wantedto make sure the harness wasnt important ...I have to runs on 1/0 ran to the back for my audio a run of 1/0 from alts charging stud and to 1/0 grounds im getting a 350amp alt when I finish this bracket and the way the sae post are they limit the amount of 1/0 runs I want to run to the back for my batteries
Sent from my SCH-I605 using Tapatalk 2
