Mad grinding in 2WD
NissanNismoZ
Er, so, the black 94 has this grinding noise, like, something is rubbing the tire, or like a can on a bicycle tire.. But pops deeply and stops. OK. It did it when I first got it, suspected the hub was bad and took out the lock ring. OK. No more problems.
So i needed 4WD to get up a mountain so I borrowed red Pathys hub and lock ring and it made the trip just fine. (not sure if this has anything to do with it) but I thought I'd exercise my reverse to my neighbors since they needed me. On my way back home, there it was. The now evem louder GRINNNNNDDDDDD POP noise.
I thought it was a fluke and ignored it since it used to go away once I took off again. Nope.
I head out to work and notice it GRINDDDDDDDD POP over and over, and making a noise like the wheel locks up for a second.
So i didnt trust it and left it home.
I never noticed it do this in 4WD
Black Pathys hub works fine in red Pathy.
Either hub does it on black Pathy.
Any idea what this can be??
I can take the lock ring out and it'll be fine again..
