nick1716 Posted December 17, 2004 Share Posted December 17, 2004 are cv boots very difficult to replace? Link to comment Share on other sites More sharing options...
88pathoffroad Posted December 18, 2004 Share Posted December 18, 2004 Well, you have to remove the axle, which involves removing many other parts first... Link to comment Share on other sites More sharing options...
Boris Posted December 18, 2004 Share Posted December 18, 2004 Inside or outside boots?? Shouldn't realy matter as you might as well replace both. You'll have to pop the drive shaft(s) out, remove one CV joint per axle, clean CV joints, apply new greese, install new boots, reinstall the removed CV joints, reinstall drive shafts. I sometimes go one step further and put the CV joints that were on the left side onto the right side and vice versa(just the CV joints not the shafts). Arm yourself with a BFH to help with stubborn ball joints. sly Link to comment Share on other sites More sharing options...
