smoke Posted October 15, 2012 Share Posted October 15, 2012 (edited) put some larger tires on the truck and was wondering if there was a easy way to change the speedo...thanx Edited October 15, 2012 by smoke Link to comment Share on other sites More sharing options...
sroeser01 Posted October 15, 2012 Share Posted October 15, 2012 I changed to a larger tire size (31x15.5r15) and didn't really worry about the speedo cause it will only affect the speed slightly but had to change the speed sensor any way later on down the road cause it stopped working. Was one of the hardest sensors I've done. Hard to get to if its stuck in there mine came out in peices then I drilled the rest out Link to comment Share on other sites More sharing options...
sroeser01 Posted October 15, 2012 Share Posted October 15, 2012 I just googled it and got some good answers. Check it out Link to comment Share on other sites More sharing options...
XPLORx4 Posted October 15, 2012 Share Posted October 15, 2012 put some larger tires on the truck and was wondering if there was a easy way to change the speedo...thanx What size tires did you put on? Link to comment Share on other sites More sharing options...
ltsnotme Posted October 17, 2012 Share Posted October 17, 2012 I switched from 235/70/15 to 265/70/15 (which is stock for the SE trim), so my speedometer is off by 5% and odometer by like 10%. Would getting a speed sensor from a 96-99 SE fix that, or is the wheel size programmed in the ECU? Link to comment Share on other sites More sharing options...
XPLORx4 Posted October 17, 2012 Share Posted October 17, 2012 No, unfortunately, I believe the speed sensors are the same. The way that Nissan "re-calibrated" the speedometer was to regear the front and rear diffs when going from 235 to 265 series tires. Models that originally came equipped with 235/70R15 tires had 4.363:1 gearing in the axles, while models that came with 265/70R15 tires had 4.636:1 gears. Link to comment Share on other sites More sharing options...
ltsnotme Posted October 18, 2012 Share Posted October 18, 2012 No, unfortunately, I believe the speed sensors are the same. The way that Nissan "re-calibrated" the speedometer was to regear the front and rear diffs when going from 235 to 265 series tires. Models that originally came equipped with 235/70R15 tires had 4.363:1 gearing in the axles, while models that came with 265/70R15 tires had 4.636:1 gears. How difficult is it to regear the diffs? Link to comment Share on other sites More sharing options...
XPLORx4 Posted October 18, 2012 Share Posted October 18, 2012 Visit your local wrecking yard and find a set of whole diffs from a 96-99 SE, or at least verify the gear ratio to be 4.636:1. Link to comment Share on other sites More sharing options...
