William Posted October 4, 2012 Share Posted October 4, 2012 Hi Guys, Just came across this on the WHITELINE website. It is for the rear end of a NISSAN PATROL. Noticed the sentence above: "Front & Center Bushes available in both Standard & Offset for Caster Adjustment. A Must for raised suspension" Does this apply to WD21? William Link to comment Share on other sites More sharing options...
Tungsten Posted October 5, 2012 Share Posted October 5, 2012 No. WD21 rear control arms are fixed caster. The front suspension is IFS so this is not even related. You adjust the caster by shimming the upper control arms up front. Link to comment Share on other sites More sharing options...
Slartibartfast Posted October 5, 2012 Share Posted October 5, 2012 Looks like the Patrols are radius-arm. Raise or lower the axle and it would twist, which I guess would strain the shock mounts etc. With enough lift this could become an issue. More likely (especially on the front axle) this could fugger up the steering angles. Pathfinders are 5-link in the back, and the links take care of keeping the axle aligned. The only reason to do link bushings during a lift is if they're worn out. And as Tungsten said, the front end is IFS, so it's a different beast entirely. Link to comment Share on other sites More sharing options...
