bushnut Posted September 16, 2012 Share Posted September 16, 2012 I've got a 2000 pathy with rusty fender wells i was figuring on trimming them, then i thought i might have room for bigger tires, then i thought about the strut in the way in the front....solution wheel spacers, or am i just out to lunch? Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 16, 2012 Share Posted September 16, 2012 As long as you have the fenders on still wheel spacers will make things worse. They will move the tire out further and cause them to hit. A tire mounted on a wheel with the proper offset will clear better than a tire on a wheel with the wrong offset, adding spacers is like running wheels with the wrong off set. Link to comment Share on other sites More sharing options...
Precise1 Posted September 16, 2012 Share Posted September 16, 2012 I generally advise against using wheel spacers as they can cause balancing issues, parallelism issues and some wheel studs arent designed for having a load cantelevered, etc. You are far better buying rims that maximize wheel size and position for the tires you want to run, with or without any suspension lift. I don't know the answers off hand, but I'm certain it is easily located in the R50 section. B Link to comment Share on other sites More sharing options...
