captandy Posted September 11, 2012 Share Posted September 11, 2012 plug wires and plugs.... so MANY choices... what do you think? Link to comment Share on other sites More sharing options...
Towncivilian Posted September 11, 2012 Share Posted September 11, 2012 Stock NGK BKR5E-11 plugs only I'd say. Any spark plug wire set from a reputable manufacturer (NTK, Beck/Arnley, Denso, AC Delco, Standard Motor Products) should work well. RockAuto is probably the cheapest place to obtain these, or possibly Advance Auto Parts if ordered online with discount code. Link to comment Share on other sites More sharing options...
XPLORx4 Posted September 11, 2012 Share Posted September 11, 2012 I use stock NGK plugs in my Pathfinder, and I've had a set of Magnecor KV85 ignition wires installed on my truck since 1999, or about 140,000 miles ago, and they still work great. Link to comment Share on other sites More sharing options...
captandy Posted September 12, 2012 Author Share Posted September 12, 2012 thanks guys.. Link to comment Share on other sites More sharing options...
pathfounder Posted September 12, 2012 Share Posted September 12, 2012 Use name brands and avoid gimmicks. You don't need fancy wires, v-plugs or anything like that. Link to comment Share on other sites More sharing options...
Tungsten Posted September 17, 2012 Share Posted September 17, 2012 OEM is always the best when it comes to Nissan ignition systems. The plugs you could be picky with as long as they are NGKs. I ran NGK V-power plugs which were great and are OEM but decided to switch to G-power plugs because they last a little longer for how much I drive. Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 17, 2012 Share Posted September 17, 2012 I always use NGK plugs on the Nissans and usually use the V powers, I usually recommend staying with stock plug wires but I have a NGK set on my sentra right now and they are working good, fit the clips and are labeled like the stock wires. Good prices as was said from Rockauto. The plugs I always get locally, not a huge mark up on plugs. Link to comment Share on other sites More sharing options...
ferrariowner123 Posted September 26, 2012 Share Posted September 26, 2012 Just adding my name on the list of guys who run NGK. I would go bosch, NGK, or OEM. all great brands. -Kyle Link to comment Share on other sites More sharing options...
ahardb0dy Posted September 27, 2012 Share Posted September 27, 2012 OEM is NGK, I would not use Bosch personally, Nissan's like NGK Link to comment Share on other sites More sharing options...
ferrariowner123 Posted October 1, 2012 Share Posted October 1, 2012 OEM is NGK, I would not use Bosch personally, Nissan's like NGK No kidding, learn something new everyday. -Kyle Link to comment Share on other sites More sharing options...
